Some FTP commands failing - SOLVED
- Everything else
- Re: Some FTP commands failing - SOLVED
29-01-2014 10:15 AM
I can log in to the FTP server, and some commands (pwd, cd) work, but others hang, time out, and fail (dir, put). 'Put' does remove the existing file at the far end, but replaces it with an empty file, not the one I want to transfer. For more details, see the attached screencap.
Is this a known problem? Is someone working on it?
Edit: subject changed to show problem is solved.
Message 1 of 5
(1,130 Views)
4 REPLIES 4
29-01-2014 2:06 PM
It looks as if this is my problem. If I understand correctly, Port 21 is used for control, Port 20 for data, so it looks as if something at my end is blocking Port 20....
Message 2 of 5
(628 Views)
29-01-2014 2:29 PM
Solved! PN's firewall blocks Port 20 on its 'High' setting. Simple!
Message 3 of 5
(628 Views)
29-01-2014 3:51 PM
Did you try passive mode? I think that should work through the firewall.
Message 4 of 5
(628 Views)
29-01-2014 5:10 PM
Yes, I tried the PASV command, which the server accepted, but for some reason it made no difference. Turning the firewall off briefly sorted the problem.
Message 5 of 5
(628 Views)
- Everything else
