Skype
southerner
Skype
Not sure if I should post this here or in the Fibre Broadband forum but I just wondered whether anyone else hits issues using Skype sometimes where either some people can't see each other or hear each other during meetings?
I think my internet connection's pretty decent?....
6267040500
4 REPLIES 4
Fixes: 1,552
Re: Skype
Hi there, I'm sorry to hear you're having problems with Skype.
Nothing wrong with those speeds. Are you video calling using a wired or wireless connection? And have you tried a different device too?
southerner
Re: Skype
Hi Anoush,
Thanks for the reply.
I'm using Skype on my laptop with a wired connection to my router.
I'll try it with another device when I have a moment to see if things look different on there.
decomplexity
Re: Skype
But if the speed at the 'other end' is poor or lumpy, you will get a bad session irrespective of your own speeds.
You could perhaps get your Skype partners also to run off speed tests
Zen from May 17. PN Business account from 2004 - 2017
southerner
Re: Skype
Valid point to check too. Thanks.
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
