SIP Traffic Allowed?
- Everything else
- SIP Traffic Allowed?
18-12-2018 8:17 AM
Hi
We have just moved to PlusNet fibre and I am interested in setting a SIP based phone system using FreePBX, this would be mostly for educational/learning reasons.
Before I start something which is going to cause me to pull my hair out needlessly - is SIP traffic blocked on PlusNet?
Lee
Re: SIP Traffic Allowed?
18-12-2018 8:34 AM - edited 18-12-2018 8:48 AM
@clydfan SIP traffic is not blocked.
When I work from home , I have a SIP phone connected into the company PBX.
However you do need to check that your Broadband Firewall setting is either LOW or OFF
https://portal.plus.net/my.html?action=firewall
If you are trying to host a FreePBX system behind your home router i.e behind NAT , then you will almost certainly need to request a static IP (£5 one-off charge) as you will need to configure FreePBX with your public IP.
Also, if you are using the PN supplied Hub one , I'd suggest getting a more configurable router, particularly one which allows any SIP Alg to be disabled as they are often broken and don't work correctly.
18-12-2018 8:55 AM
Moderators Note
This topic has been moved from Tech Help to Everything Else
