Reverse dns exposing user name
Dellibobs
My ip address seems to have changed to static (rebooted router several times and it did not change) and consequently my reverse dns is now username.plus.com. This means that my username is now exposed on reverse dns. I did not ask for this change, so please change my reverse dns to not use my username or change me back to dynamic dns where reverse dns does not contain username as far as i remember.
7 REPLIES 7
Fixes: 246
Re: Reverse dns exposing user name
Have you recently changed the account based firewall settings?
Dellibobs
Yes i did, a few days ago. Why do you ask?
Fixes: 580
The firewall requires that the connection is via the 'high touch' network, which means a static IP is applied.
Dellibobs
Ah! Didn't know that. Thanks very much for the tip. So if I turn the firewall off (it is set to LOW at the moment) will I revert to a dynamic IP?
Fixes: 580
I believe so
Dellibobs
Thanks, I'll give it a go and report back results in a few days.
Dellibobs
Yup, about 36 hours after turning firewall off I have reverted to dynamic ip and the rDNS has changed back to [ip-address-bacwards].dyn.plus.net.
Many thanks @MisterW and @Townman for your help.
