Reverse DNS record
naglya
Reverse DNS record
Hello,
I have a static IP-address. How to update my PTR-record to my domain name?
Thank you in advance!
11 REPLIES 11
adamwalker
Fixes: 223
Re: Reverse DNS record
Hi @naglya I can sort that out for you. What's the domain please?
Adam
 Adam Walker
naglya
Hi Adam,
Domain hovernails.co.uk.
Thank you!
Fixes: 581
@naglya you will need to ensure that there is an A record for your domain, that points to your static IP. That will be checked before the rDNS can be set to your domain
naglya
Yes, I already host a tiny site on that address
adamwalker
Fixes: 223
Cheers @naglya I've put the request through for you. That should update within the next 24 hours.
Adam
 Adam Walker
naglya
Hello Adam,
No any changes yet.
@adamwalker could you check your request?
Thank you!
James30
Fixes: 32
@naglya hi, I wasn't able to track the request as Adam isn't in but I've resent it now.
James - Plusnet Sheffield
naglya
Thank you, James!
naglya
@James30 It looks like your request was also lost
James30
Fixes: 32
@naglya - I've double checked and the task is still open waiting to be picked up. 5 working day is a more realistic time frame for them to action it.
naglya
The record was updated today.
Thank you!
