Reverse DNS name on my static IP
FIXED- Subscribe to RSS Feed
- Everything else
- Re: Reverse DNS name on my static IP
15-12-2020 4:44 PM
Hello, I have recently obtained a static IP. However, it reverse resolves to myusername.PLUS.COM, which is not ideal for privacy while browsing.
I see that others have had success in getting the reverse DNS name changed to something like xxx.xxx.xxx.xxx.ip.PLUS.COM, which would be ideal.
I raised a ticket to do this, as was suggested in other posts. However, the response I received is
"Unfortunately reverse DNS is not something that we currently support. however you may find additional support around this subject on our community support forum."
which is less than satisfactory. Can anyone connect me with someone who knows what I am talking about? 🙂
Fixed! Go to the fix.
15-12-2020 5:12 PM
Yep it'll need the PTR record removed on your static IP, which I believe it is something PlusNet can do?
16-12-2020 3:44 PM
Thanks for your post @rhc
I've raised this to our NetOps team to review and I'll let you know once they've got back to me
17-12-2020 8:30 AM
17-12-2020 7:48 PM
Brilliant, thank you.
Have a happy Christmas.
- Everything else
