Reverse DNS name on my static IP
rhc
Hello, I have recently obtained a static IP. However, it reverse resolves to myusername.PLUS.COM, which is not ideal for privacy while browsing.
I see that others have had success in getting the reverse DNS name changed to something like xxx.xxx.xxx.xxx.ip.PLUS.COM, which would be ideal.
I raised a ticket to do this, as was suggested in other posts. However, the response I received is
"Unfortunately reverse DNS is not something that we currently support. however you may find additional support around this subject on our community support forum."
which is less than satisfactory. Can anyone connect me with someone who knows what I am talking about? 🙂
Tags (2)
4 REPLIES 4
Alex
Fixes: 13
Re: Reverse DNS name on my static IP
Yep it'll need the PTR record removed on your static IP, which I believe it is something PlusNet can do?
Fixes: 1,600
Thanks for your post @rhc
I've raised this to our NetOps team to review and I'll let you know once they've got back to me
Fixes: 1,600
We've actioned this last night so the rDNS should update by tonight
I hope this helps
rhc
Brilliant, thank you.
Have a happy Christmas.
