Remove devices from McAfee
jing
I have 7 devices on my Mcafee account that's bundled in as part of PlusNet Protect. However, none of them are in use, so need to be removed. Unfortunately, I can't seem to find a way of doing that from the McAfee web page.
I literally just need them all removing from my account so I can download McAfee on to my current devices. Anyone know how I do that please?
Thanks.
10 REPLIES 10
Fixes: 1,662
Re: Remove devices from McAfee
Hi @jing
We'd have to arrange for McAfee's Support Team to call you back to remove the devices from their side.
Can you drop me a private message with your account username, a contact number to reach you on and a timeframe when you'd be available for a call?
Tryinghard
I have same issue
Fixes: 1,662
@Tryinghard
Feel free to drop me a private message with the above info^ and I can arrange a call back from McAfee Support.
Tryinghard
After a PM to Plusnet McAfee soon phoned and sorted.
LaurenB
Fixes: 131
I'm pleased to hear you've had a call and got this sorted @Tryinghard, just get back to us should you have any further queries.
 Lauren Barry
jing
So I just got off the phone with McAfee and they told me that there's no need to remove the devices and that I should be able to continue installing the product.
I'm on a Mac, and they said they don't know if PlusNet provides a license for Mac, do you @Gandalf?
Honestly, the McAfee person was pretty dismissive and useless, frankly. I think I'll probably just go an buy some AV elsewhere.
Tryinghard
The Plusnet site says up to 7 PCs
Fixes: 387
@jing The McAfee product via PN is NOT compatible with Macs - it is Windows only, and to be honest I wouldn't use it anyway.
jing
@jab1 appreciate the follow up. I already went ahead and purchased a Bitdefender license. 👍
LaurenB
Fixes: 131
Hiya @jing, as @jab1 has mentioned, it isn't compatible with Mac. Should you have any further queries, please don't hesitate to get back to us.
 Lauren Barry
