Remove Username From Hostname
jacob
Please remove my username (which contains my full name) from the reverse record on my Static IP
Looking at previous threads it seems that posting here is the correct way to request this
12 REPLIES 12
adamwalker
Fixes: 223
Re: Remove Username From Hostname
Hi Jacob, I've just checked your account and can see it's already been done.
Do shout up of there's anything else you need from us.
Adam
 Adam Walker
jacob
Thanks Adam,
Do you know how long it will take for the nameserver to update (it is still returning my username)?
willcutforth
Fixes: 113
It's usually within 24 hours, what's it showing now from your side?
 Will Cutforth
jacob
Still showing my username
willcutforth
Fixes: 113
Leave it with me, I will need Adam to comment on the task to inform them.
 Will Cutforth
adamwalker
Fixes: 223
Hi Jacob, sorry for the delay to this, there's been an issue with the original request for this that got raised for you. I'll get it put straight. What would you like the RDNS to be set to instead of showing the username? - Adam
 Adam Walker
jacob
Thanks Adam!
Please set it to anything non-identifiable, random string, whatever
adamwalker
Fixes: 223
No probs, I've raised a new task for that now and I've added details onto your account here to confirm: https://www.plus.net/wizard/?p=view_question&id=235383327
Adam
 Adam Walker
jacob
Hi, the support ticket was closed with the following detail:
"Thank you for your message in regards updating the rDNS to your IP address instead of the username. It is not possible for this to be done your static IP is unique to your account connection and the address is connected to your Plusnet account."
I recall seeing numerous posts here where other customers had the same request completed - is it no longer possible? How else can I remove my full name from the reverse DNS record?
Fixes: 392
@jacob  - you need either @adamwalker  or @willcutforth to suggest the job gets done properly - that response on the ticket was a load of rubbish.
James30
Fixes: 32
@jacob - I've reraised the task to update the RDNS. The previous task wasn't raised correctly and was closed. I'm sorry for that.
James - Plusnet Sheffield
Fixes: 392
@James30 A second time?Huh
