Redirecting https
ragiggman
Redirecting https
I am currently redirecting from my web space vodden.plus.com to my wordpress.com site using:
<meta http-equiv="refresh" content="0;URL=http://petervodden.wordpress.com" />
I (and others of my friends and acquaintances) have noticed that some people have started to use https:// as a default when linking (why, I don't know, seems daft to me - why would you request a simple personal website encrypted? - but it is happening..).
So requesting https://www.vodden.plus.com just responds with a "Privacy Error" in the browser - I assume because because the redirect mechanism cannot pass a certificate.
Should I redirect to https://petervodden.wordpress.com - will that work?
Or, if I switch to a CNAME enabled redirection, will the DNS server then pass a certificate to https://petervodden.wordpress.com?
If not, is there another way around this problem?
Any assistance gratefully received.....
7 REPLIES 7
decomplexity
Re: Redirecting https
Do you get a similar error if you do the redirect via JScript, e.g.
<script language=JavaScript type=text/javascript>
window.location = https://petervodden.wordpress.com
</script>
Zen from May 17. PN Business account from 2004 - 2017
ragiggman
Yes. I have updated the index.html page to include:
window.location = "https://petervodden.wordpress.com";
</script>
That makes no difference.
If the problem is SSL, then I wouldn't expect the mechanism (refresh, script, CNAME etc.) to make a difference. If the Plusnet server has no certificate for  https://www.vodden.plus.com, the it can't negotiate with the server at Wordpress. I'm not an SSL expert, but I have read that a lot of server administrations wrongly assume that redirecting https to another https doesn't need a certificate - but it does.
bobpullen
Fixes: 290
Use https://homepages.plus.net/vodden
ragiggman
Sorry, Bob, I am not quite sure I understand.
Do you mean use a CNAME record to send any incoming request for my vodden.plus.com domain to
homepages.plus.net/vodden which then will handle any redirection expressed in code in my index.html page?
bobpullen
Fixes: 290
Ah, may have misinterpreted the ask. I wonder if an htaccess directive to rewrite https://www.vodden.plus.com to https://homepages.plus.net/vodden would work?
Edit: on second thoughts it wouldn't as it would fundamentally break what SSL is there to do in the first place. I don't see a solution to this. Either those linking need to use https://homepages.plus.net/vodden, or visitors will have to put up with the error.
ragiggman
Yep I agree. There is no solution.
I am guilty of using a method for temporary redirection in a manner for which it was not designed.
What I plan to do is update the DNS settings. It means I will no longer be able to serve up resources from my Plusnet webspace - but at least I can still utilise my FTP service for file storage. (I think - is that correct?)
Chris
Legend
Fixes: 169
You can use the homepages to store files up to the allowance there, that shouldn't be an issue -Chris
