Problem with Mambo 4.6.2
- Everything else
- Problem with Mambo 4.6.2
07-10-2007 10:42 PM
I have installed mambo 4.6.2 it is set up correctly as far as I can see.
But when I try to move off the HOME page I get 'Not Found' and The requested URL /files/home2/interference/index3.php was not found on this server. Even though the file is there.
site address is www.guild-interference.org.uk
Any ideas anyone.
Any ideas anyone.
Message 1 of 3
(1,462 Views)
2 REPLIES 2
Re: Problem with Mambo 4.6.2
08-10-2007 12:09 AM
Is /files/home2 within your root directory?
When you set-up Mambo, did you specify any full path names which included /files/home2/..... ?. If you did you may have entered the full path incorrectly as it should be:
/files/home2/username/yy
where username is your plusnet account name and yy is any sub-directory you need to specify within your root folder.
Message 2 of 3
(236 Views)
08-10-2007 12:51 AM
Hi peter.
The file is in the root directory of the site.
Mambo 4.6.2 uses your absolute path within the global settings, and reads this on the cgi server as "/share/storage/02/in/interference/" in my case.
Found the problem ::).
In Global settings there is a tab called "SEO" 'Search Engine Optimization' with an option for "Search Engine Friendly URLs:"
I had selected 'Yes' and could not get past the home page. I have now selected 'No' and links are now working.
Lets hope that this is the only glitch with it ;D.
Message 3 of 3
(236 Views)
- Everything else
