Plusnet Username publicly visible via IP Locators
DdAaNn
Re: Plusnet Username publicly visible via IP Locators
Hi @Townman,
Thanks for your feedback, that's useful information to know. Will the relevant staff pick up the request from this comment/thread or so I need to make a more official request?
Thanks again
Fixes: 246
I am sure that this thread will be sufficient to garner assistance from a staff member...
seebee
Fixes: 9
I thought that if you were on a dynamic IP, but had turned on the Broadband Firewall in the Plusnet portal that would happen to give you a reverse IP name of username.plus.com
The Plusnet Broadband Firewall is controlled here - Broadband Firewall | Member Centre | Plusnet
I have mine set to off, and don't have time to test it this morning, so have a reverse address like x.x.x.x.dyn.plus.net - I'm sure in the past when I have turned it on, I then get a reverse of username.plus.com
Its mentioned here by @Gandalf - Re: Help with user name, account name. - Page 2 - Plusnet Community
"...To clarify the bit about the static IP you do have one we've automatically added free of charge, because the broadband firewall is activated. We'd automatically apply a static IP if you enable the broadband firewall, ..."
Fixes: 383
@seebee Now you mention it... Never had the BB firewall on, so that's why I always had a dynamic IP. Presumably it had to be static for the firewall to work?
Fixes: 580
Yes, I believe if you turn on the firewall you will get allocated a static ip
It's to do with routing changes to allow the firewall, to work
DdAaNn
I do have the BB firewall switched on at the 'Low' setting.
Hopefully a staff member will show up shortly to correct my rDNS so it stops showing my personal information.
Fixes: 383
@DdAaNn It is Sunday - low staff levels, and posts are picked up in earlyist-latest sequence.
Fixes: 246
Interesting linked to post. That looks like an inexpensive means of obtaining a static IP and protecting one’s connection in one fell swoop!
Off topic but I could only smile at the delusional concerns over security risk of a static IP address. Sure AV vendors will seek to install fear as that bolsters their sales pitch. The reality is that any assigned IP address is effectively static … unless your broadband suffers frequent and prolonged disconnections!! A dynamic IP address is assigned for the duration of the PPP session. If the PPP session break is brief, there is a good chance that the same dynamic IP address will be reacquired especially as these are now assigned in the local exchange.
Fixes: 383
Thanks, @Townman . As you say, AV manufacturers need to instil fear to keep selling their 'new, improved' kit, which generally does nothing but gobble resources. I have 'Avast' installed on my Windows machine and the garbage it keeps reporting as a 'threat' makes me burst out laughing.
The Linux machine -no such garbage from Clam AV, which I often forget is there, it is so unobtrusive, in fact in my configuration, I have to manually 'wake' it if I suspect there maybe an issue - always come back clean, though.
bobpullen
Fixes: 330
@DdAaNn - I've requested that the reverse DNS for your IP address is changed. Will likely take a day or two.
DdAaNn
@bobpullen Thanks for your help with this. I'll wait for it to be update and then mark the ticket as solved.
As a note isn't it bad practice for Plusnet to display usernames in the rDNS like this? Seems like it could easily be a security issue to be giving out usernames openly like this, even more so when usernames will often contain a users full name as is my case.
Fixes: 246
No, not at all, it is normal good practice for rDNS to resolve an IP address back to the URL used to look up the IP address. It is a well used security check that a resource is what it claims to be.
Now if you asked if it is wise for an account name to be used as part of the domain name on that account … such would be a more searching question about best security practices.
DdAaNn
Yep, apologies, this is what I was (rather clumsily) trying to say.
Seems as if this is something that should be looked at at a higher level than just updating the rDNS when a user stumbles across it and reports it as I did.
Fixes: 383
Out of curiosity, I wonder how long this situation has lasted, and has it had any adverse effects during that time?
Fixes: 246
It impacts only a small portion of the user base - those with static IP addresses by whatever means. I suggest that on the basis that a user has a strong password on their account the exposure here is not significant, even if the practice is deemed not ideal.
IIRC on account sign up there is a clear warning that the account name does become exposed in one’s domain name (email address in the days of email being part of the package).
