Plusnet Protect to Norton?
amuckelt32
I note that BT are offering Norton as their security software. Will Plusnet be offering the same and moving away from McAfee?
13 REPLIES 13
Fixes: 479
Re: Plusnet Protect to Norton?
@amuckelt32
BT branded Retail services and Plusnet operate as separate companies with a different range of services, hardware and pricing structure. Why would they offer the same Internet Security software?
amuckelt32
Thanks for your helpful reply
amuckelt32
Well, well as I assumed would happen the move to Norton has happened!
Fixes: 1,495
I had an email today as well
agedgopher
All Star
Fixes: 15
I have just checked my account because it is billing day today. \in the add-on section Norton is offered instead of McAfee.
kissinuk
@Baldrick1 wrote:
@amuckelt32
Hmm, sadly that last question hasn't aged well. My main issue with this is that after 2 years it looks like it's no longer included for free.
Fixes: 1,495
Yes, noticed that too. Not great.
Says free on my account, still up to seven devices.
Seems an improvement as supports more than just windows pc.
Edit Not that I'll be taking the offer up
kissinuk
From the email I received:
"...free of charge for the next 2 years and after that Norton will get in touch with details on how you can renew the service."
But yes, the mobile offering is a plus.
Fixes: 1,495
Plus password manager etc.
greygit
I think it happened about a week ago. I checked up via the PN website about then and noticed it but decided not to say anything.
greygit
It happened on or before 31st May
From - Tue, 31 May 2022 09:21:42 GMT
X-Mozilla-Status: 0001
X-Mozilla-Status2: 00800000
X-Mozilla-Keys:
Message-ID: <redacted>
Date: Tue, 31 May 2022 10:21:41 +0100
MIME-Version: 1.0
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:91.0) Gecko/20100101
 Thunderbird/91.8.0
Content-Language: en-GB
To: redacted
Subject: Plusnet add-ons
Content-Type: text/plain; charset=UTF-8; format=flowed
Content-Transfer-Encoding: 8bit
It used to be McAfee
now...
"Plusnet Protect powered by Nortonâ„¢ (included)"
Well, that's changed in the past day or three.
pwilliams62
When installing Norton to replace McAfee in Plusnet Protect I advise starting on an administrator account.
Often, if I install new programs on my local account and administrator rights are required, I just get a pop-up to enter the password or pin. This did not happen when I tried installing Norton from the Plusnet message.
I started on a local account on my main computer and had to stop when told to switch to my administrator account. I completed the installation on the administrator account but when I went back to the local account the original paused installation continued on and created a different Norton product number to that on the administrator account. Similarly, when I installed Norton on my second computer I had a third different product number. This confused me because I should have one product No with "licence 1 of 7", "licence 2 of 7" and "licence 3 of 7". I found the setup and initial use very confusing and believe we should have been provided with more detailed instructions or a tutorial.
The confusion continued when Norton kept asking me to download protection every time I logged in and I ended up with four NortonNSDownloader.exe, (1), (2) and (3). Then there was the confusion around Google Chrome extensions. I kept getting offered Norton Safe Web and Norton Safe Search even after I had already installed them. Safe Search is easy to understand but I have failed to distinguish between that and Safe Web.
Norton Power Eraser is easy to understand but I have given up on Norton Insight and Diagnostic Report. I have no idea what to do with these. Do we have to keep applying these various system scans to protect our PCs or is the system monitored continuously during use?
I picked "Open" next to the down arrow and got "You are protected" but next to it there is "Internet Security" - Not set up. Confusing!
