Plusnet Protect is Expiring?
Johnnie_Dee
Over the past couple of days, Windows 10 has started giving me pop-up notifications that my antivirus software is about to expire.  It now says is will expire in 4 days.
When I open Plusnet Protect it says my subscription is 'Active' but gives no further details.
Should I be worried?  Any ideas what might be happening?
5 REPLIES 5
Chris
Legend
Fixes: 169
Re: Plusnet Protect is Expiring?
I can't see any issues with the service for this on your account. If you continue to receive the warning sometimes it's worth uninstalling Mcafee and then downloading from our website again.
Johnnie_Dee
OK thank you.  That's helpful to know.
I'll keep an eye on it and, if necessary, reinstall.
Thanks again.
Fixes: 1,601
No problems, let us know how you get on.
Johnnie_Dee
I'm not sure what was causing the warning message but 4 days have come and gone and Plusnet Protect is still working just fine.
Chris
Legend
Fixes: 169
Good to hear!
