Plusnet Protect is Expiring?
FIXED- Subscribe to RSS Feed
- Everything else
- Re: Plusnet Protect is Expiring?
23-05-2017 11:29 AM
Over the past couple of days, Windows 10 has started giving me pop-up notifications that my antivirus software is about to expire. It now says is will expire in 4 days.
When I open Plusnet Protect it says my subscription is 'Active' but gives no further details.
Should I be worried? Any ideas what might be happening?
Fixed! Go to the fix.
23-05-2017 11:59 AM
I can't see any issues with the service for this on your account. If you continue to receive the warning sometimes it's worth uninstalling Mcafee and then downloading from our website again.
23-05-2017 12:12 PM
OK thank you. That's helpful to know.
I'll keep an eye on it and, if necessary, reinstall.
Thanks again.
23-05-2017 7:20 PM
30-05-2017 8:16 PM
I'm not sure what was causing the warning message but 4 days have come and gone and Plusnet Protect is still working just fine.
31-05-2017 9:14 AM
Good to hear!
- Everything else
