ONT Query
pvmb
Champion
Fixes: 15
ONT Query
Does anyone know what the function of the 'Alarm' light is on the Openreach ONT (No. It isn't on!)
13 REPLIES 13
Fixes: 387
Re: ONT Query
Yes - it indicates when there is a fault/break between the ONT and the 'outside world' - or in my case recently, a failure of the ONT itself. You never want it to go on. 😀
Fixes: 583
Re: ONT Query
@pvmb I didnt know there was an 'Alarm' light on recent ONTs. IIRC on early ones with battery backup there was an ALARM on the BBU. Lights on mine are PWR, LOS, PON & LAN
Can you post a piccy
Fixes: 387
Re: ONT Query
@MisterW My Adtrans ONT has 'ALARM' 'LAN' 'PON' 'POWER' left to right.
pvmb
Champion
Fixes: 15
Re: ONT Query
Here is picture of ONT. Could have turned it around I suppose. Sorry!
Just noticed from the photo it has its own ON/OFF switch.DSCF1265.JPG
Fixes: 387
Re: ONT Query
And mine:
Re: ONT Query
My ONT has a LOS LED, so maybe it's called ALARM on yours
EDIT: it normal status is OFF
Fixes: 251
Re: ONT Query
Images approved.
Fixes: 583
Re: ONT Query
Likewise
That would be my conclusion as well
edit: although maybe not ?
on @pvmb s photo the PON is red, and on @jab1 s its green, whereas on ours the PON is only either GREEN or OFF.
so does the PON light handle both the PON and LOS functionality on later ONTs ?  with the ALARM meaning someting else ?
Fixes: 387
Re: ONT Query
@MisterW When my ONT failed the 'Alarm' light went orange. Talking to the OR engineer when he came, his first comment was 'I don't feel like going up ladders/down holes today' (with a grin), so he just checked my light levels and said 'they're good', fetched a new ONT, and 'hey voila' I was back up in 20 minutes or less, so I'm guessing the 'Alarm' is the 'LOS' light, renamed?
Re: ONT Query
@MisterW
Looking at @pvmb it has no LAN cable connected either, so I'm wondering it the circuit is live?
Fixes: 583
Re: ONT Query
@Dan_the_Van from other posts I don't think it is yet! There's been some confusion within OR ( nothing unusual there then )
DerekW
Re: ONT Query
That is what the lights on my ONT looked like, one red and one green,  until I emailed the CEO of Openreach asking him to sort it... which they did PDQ.
The reason for my light being red was because there was a problem with the light at the exchange
The lights on my ONT, from left to right are, Alarm - LAN - PON - Power
LOS I believe stands for loss of service.
"No one has ever become poor by giving" - Anne Frank
Fixes: 387
Re: ONT Query
Correct - now called 'Alarm', because, I'm guessing, it doesn't just cover loss of service, but other fault conditions, too.
