ReverseDNS change
mb251
ReverseDNS change
I would like to change my ReverseDNS name. I contacted PlusNet via phone to request this but got told it was something I could do at my end and then sent instructions about changing DNS, which does not appear to apply.
I can find no way to raise a support ticket or request this change directly in my PlusNet account login, which I find bizarre. It appears the only way I may be able to get this change implemented is by posting on this forum, which does seem an odd way of handling support requests. I have a few questions that I would be grateful for some assistance with please:
1) How can I be sure that anyone contacting me via the forum is a genuine PlustNet employee and not a scammer looking to obtain sensitive details from me?
2) I currently have a dynamic IP address. Is a static IP address required to change the ReverseDNS?
3) If I need or want to switch to a static IP address, can this be the same address I am currently assigned as a dynamic address?
4) How much disruption could I experience switching to a static IP address?
6 REPLIES 6
Fixes: 251
Re: ReverseDNS change
The advice you was given is totally wrong.
This is not something you can do via DNS.
Why do you want to do this?
If you do not have a static IP address already you cannot now obtain one.
rDNS can only be applied to a static address.
mb251
Thanks for your reply.
I suspected the advice was wrong.
I want to change the ReverseDNS for privacy reasons, as it is currently set to my PlusNet username, which contains my surname etc.
What are my options please?
Fixes: 387
If it is 'currently set to my user name', you already have a static IP.
To answer your original question (1) Genuine PN employees on here are identified by a 'staff' tag on their avatars.
plusnettony
Fixes: 74
If you have a static IP, can you pm me your username please, and I'll sort it when I log onto the server.
 Tony T
Fixes: 251
If the rDNS references your account name then you DO have a static IP address.  Call support and ask them to raise a request on Net Ops.  If they do not know how ask them to consult Albert.  If that fails ask for a manager.
Alternatively wait for a staffer to pick up this thread.
EDIT: posts crossing everyone is over this like a rash this morning!!!
Fixes: 387
Deleted.
