Moving my EXTERNAL openreach cable
SirSpamalot
Hi, Because of building work, i need to move where my fibre line comes through the wall of the house. Trying to convey this on the support pages is... challenging. I know I will need openreach. I expect it will be chargeable. Both of those are fine, I just need it doing!
Any ideas?
6 REPLIES 6
Fixes: 248
Re: Moving my EXTERNAL openreach cable
The call centre ought to be able to arrange this for you.
SirSpamalot
No joy with them so far
mystreet1
Seasoned Pro
Fixes: 7
This thread will answer it for you
https://community.plus.net/t5/Everything-else/Moving-existing-FTTP-connection-to-avoid-building-work...
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
SirSpamalot
!Thanks
Sorted thank you verymuch
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to Everything Else
Fixes: 117
@SirSpamalot
This is one of those rare occasions where you can contact OpenReach directly.
There is a form on their webpage that promises a call back with 3 days to discuss the work required.
If doing building work it's an ideal time to consider whether to run ethernet cables to help internet coverage in the house.
