More on IP address stability
pvmb
Champion
Fixes: 16
Interesting?
By looking at some Wikipedia User talk pages addressed to myself, dating from 2021, (before I had a Wikipedia account) I see my then Plusnet IP address was identical to my current Plusnet IP address.
Is this a record? 😄
5 REPLIES 5
markhawkin
Champion
Fixes: 22
Re: More on IP address stability
You don't by any chance have the (now no longer available) "static IP address option" do you.
Failing that, I wonder if you use something like the Plusnet "safe" DNS, that may cause the IP address to remain the same.
pvmb
Champion
Fixes: 16
I have never had a Plusnet static IP option.
My Plusnet Hub 2 router itself uses the default PN DNS servers. I seem to vaguely recall something about a PN 'New Network' or something that means people just do effectively have fixed IPs. But I was genuinely surprised to find I am now on the same IP as back in the day when I was still on ADSL 2+ with a PN supplied Technicolor router.
Fixes: 251
What do you mean by “my address”?  That of your Plusnet hosted website or your connection address?
The latter being consistent across product changes, without having a static IP address option seems unlikely … unless you used the Plusnet connection side firewall.
RealAleMadrid
Fixes: 68
@pvmb  You may not have asked for a static IP address but there are some situations where you get one automatically.
Using the account based firewall or the Safeguard DNS servers are two possibilities, I think that could explain your long lived IP address.
Fixes: 585
Using the firewall is but using the Safeguard DNS isn't
