Mobile Broadband versus Full Fibre
paul1974
Re: Mobile Broadband versus Full Fibre
Thanks for the link. The Ofcom checker says Ultrafast is available.
Fixes: 374
@paul1974 wrote:
I'm in a building with flats. The other flat has FTTP, but mine doesn't. Does that sound like someone has made a mistake or does FTTP not work for flats above ground level?
Is this a conversion, or built as flats?
pvmb
All Star
Fixes: 13
@Dan_the_Van wrote:
Suggest you check using this site https://checker.ofcom.org.uk/en-gb/broadband-coverage as it expands the search beyond openreach.
I've been playing with that, with puzzling results for where I live. Here are three results for neighbours all in the same postal code, showing only the results for fibre, which is available here. I am connected to FF:
Ultrafast 1000 Mbps 100 Mbps <-- Mostly (i.e. Available, likely not connected)
Ultrafast 1800 Mbps 220 Mbps <-- Me (Openreach connected - also showing landline speeds!)
Ultrafast -- Not available --        <-- All my immediately adjacent neighbours!
Interestingly, Virgin Cable is available here, but NOT to me and my immediately adjacent neighbours. I don't know if this can explain the above anomaly.
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to Everything Else.
Fixes: 110
@paul1974
If the address version of the Checker is showing WBBC FTTP as Available for your neighbours in the block of flats but not yours then this sound like a OpenReach database problem. It's been known.
You could phone PN and ask thenm to run a check but there is a way to contact OR directly. I don't have the exact website available to me but I believe if you use the following you get offered further options if FF is available.
https://www.openreach.com/fibre-checker
If not, have a good look around the OR website.
Edit : Found the address
https://www.openreach.com/forms/fibre-broadband-availability---customer-form
paul1974
@jab1 wrote:
@paul1974 In that case, I suggest you ask Plusnet to raise an ORDI request to ask Openreach to check their database.
I spoke to Plusnet support. They've asked Openreach to fix their database. A non-existent obstruction was listed at our property. Apparently that was the reason why I couldn't have full fibre.
Thanks for your assistance.
Fixes: 374
Good result, @paul1974
