Joomla session timeouts - getting logged out
- Everything else
- Joomla session timeouts - getting logged out
20-11-2007 11:52 AM
Hi
Have got Joomla running fine except.... - I have been trying to find the post re. Joomla session timeouts.
There is no access to php.ini o so how do I stop session timeouts every couple of seconds when I log in?
It also usually takes severalk goes to login in.
Any ideas?
Any ideas?
Message 1 of 2
(987 Views)
1 REPLY 1
Re: Joomla session timeouts - getting logged out
02-12-2007 7:45 PM
Which host are you using?
You can use ftp to open up the configuration.php and change the timeout line from there
line 43 $mosConfig_lifetime = '1200';
Or from within control panel/
site/global confiruration/server
5th line down site session lifetime.
A
A
Message 2 of 2
(83 Views)
- Everything else
