Embedding XSPF player in webspace
- Everything else
- Embedding XSPF player in webspace
29-11-2007 10:18 PM
I am at the moment attempting to test a embedded flash audio player called xspf on my site. The player loads without a problem but the playlist does not all files are in a folder called audio. The message on the bottom of firefox is "awaiting www.beefeater.plus.com"; I'ved tried changing the plalist file extension from xspf to txt and altering the html accordingly but it has made no difference any suggestions?
Message 1 of 3
(2,194 Views)
2 REPLIES 2
Re: Embedding XSPF player in webspace
29-11-2007 11:29 PM
try
http://www.beefeater.plus.com/audio/xspf_player.swf
as this will work.
Try looking at the tutors
http://www.boutell.com/newfaq/creating/audio.html
http://lists.musicbrainz.org/pipermail/playlist/2006-August/001003.html
Its a bit strange as I saved you website and the playlist work from my pc but I uploaded to my website and it didnt.
I have had problems with flash before with the cross main security not letting things load
The boutell site has a free improved player which may be worth trying
as this will work.
Message 2 of 3
(414 Views)
30-11-2007 9:40 PM
Problem solved.
If I put all the components in one folder ( html file, mp3's, playlist, and player) it works o.k. (weird).
Thanks for the assist!
Message 3 of 3
(414 Views)
- Everything else
