Included .co.uk?
- Everything else
- Re: Included .co.uk?
Included .co.uk?
09-01-2014 1:33 PM
In which case does the plusnet control panel allow delegation to external nameservers as I'd want to use my own hosting.
10-01-2014 11:11 AM
11-01-2014 10:33 PM
Can't think of any .co.uk's worth registering at the moment anyway and I'd not want to move my existing domain.
11-01-2014 10:52 PM
11-01-2014 11:26 PM
I used to have 3 hosted on completely different networks, but it worked out cheaper/easier to outsource the redundant servers to a DNS hosting provider.
That said It depends what the domain is pointing at as to if I bother to use Redundant nameservers or point the domain at the same physical box for both primary and secondary DNS.
For my domains that I use email on then it absolutely makes sense to have multiple name servers to avoid losing email if the primary goes down but for some of my others they could fall off the internet for a week or more and it would be no great loss.
Edit:
I was only asking about the domains on the off chance I wanted another .co.uk, I'd normally use someone else to register my domains but I think I get 2 included with the broadband.
12-01-2014 3:22 AM
F9 member since 4 Sep 1999 F9 ADSL customer since 27 Aug 2004 DLM manages your line the same way DRM manages your rights. Look at all the pretty graphs! (now with uptime logging!) | ![]() |
12-01-2014 4:28 PM
Quote from: avatastic hexonet (because they're the only .co.uk registrar I've found that will let me set IPv6 glue)
See also Mythic Beasts.
Gabe
12-01-2014 5:02 PM
