How do i?
Jovetic
How do i?
Hi guys,
Could anyone offer some advice please on how i would possibly get my forums url to be the same as my website please.  I am not sure if i can or not.
Forums
http://ccgi.jovetic.plus.com/
Website
www.jovtech.co.uk
11 REPLIES 11
bobpullen
Fixes: 290
Re: How do i?
See 'Pointing your domain at the CGI server' here.
Does that help?
Edit: fixed hyperlink.
Jovetic
Re: How do i?
Broken link
Forbidden
You don't have permission to access /programme_tool/job.html on this server.
Apache/1.3.34 Server at workplace.plus.net Port 443
Chris
Legend
Fixes: 169
Re: How do i?
*prods Bob*
Fix your link!
bobpullen
Fixes: 290
Re: How do i?
Embarrassed
I've now edited the link.
zubel
Re: How do i?
Methinks Bob meant this link
/pat
B.
Jovetic
Re: How do i?
Thanks, think i got it, not sure.
Left  field  Type Pri Right field
ccgi  cname              ccgi.jovetic.plusnet.com
So now what else do i need to please?  If your busy i can check back later no probs.  Just playing around with it.
Jovetic
Re: How do i?
So once it is configured, my forums will be www.ccgi.jovtech.co.uk ? is that correct?
zubel
Re: How do i?
Your forums will be:
http://ccgi.jovtech.co.uk
You need to raise a ticket asking the support guys to action their end of the domain change, otherwise the CGI server wont realise that it's supposed to 'answer' to that address
Simply raise a ticket saying: "I've added ccgi.jovtech.co.uk to my domain records, please can you arrange for the ccgi server to respond to this domain"
B.
Jovetic
Re: How do i?
Already done it thanks baz, you have a fan here Tongue
Jovetic
Re: How do i?
What would happen if i changed the left field to forums other than ccgi?
zubel
Re: How do i?
I believe that the CGi server will only respond to ccgi. cgi. or www.
no other subdomain is supported, although I'm sure one of the PN guys could clarify.
B.
