Historical madasafish domain
ptwilliams
Hi
I would like to speak to someone about a historical madasafish domain that I still have.  Who would be the best person to contact please?
Pete
6 REPLIES 6
Fixes: 237
Re: Historical madasafish domain
Best just ask your question here...
ptwilliams
Thanks for the reply...
I have a historical mail account with madasafish where mail directed at a particular domain is redirected to me.
If I would like to transfer that domain to a new provider how would I go about doing that?
Kind regards
P
Fixes: 237
To transfer a domain you need to select a registrar and initiate the transfer process. Assuming it’s a .co.uk domain, all that then needs to happen is have Plusnet change the ISPTAG on the domain. You can do that by raising a request here.
Personally I have used LCN.com for domain registration (and hosting which is a different consideration) - I have found domain name transfers very easy. There are other registrar and hosting providers available.
ptwilliams
Thats brilliant, thank you.  Is there a special section to raise a request or do I just list it in a normal forum message?
ptwilliams
Actually just spoke to someone who got it fixed for me straight away.  Super impressed with PlusNet support on this one...
Fixes: 1,642
Hi Pete,
I've taken a look at this for you and it doesn't look like we had actually been registering or hosting your domain.
Doing a who.is lookup via Nominet Here of your domain from your Madasafish account shows a different provider entirely.
Could you drop me a PM with your domain name so I can check we're looking at the right one?
