FuzzyLime CMS setup
- Everything else
- FuzzyLime CMS setup
FuzzyLime CMS setup
29-06-2010 3:59 PM
hi,
I am trying to install the FuzzyLime CMS to improve the look and eventual content of my long neglected site.
The install instuctions are fairly short and it basically says upload the unzipped fuzzylime folder to your and then run the install script.
I can browse the folder from my browser and can see an install.php script but cannot run this. Have I put the folder in the wrong place?
Any help with this would be much appreciated.
Kevin
Kevin
Message 1 of 4
(841 Views)
3 REPLIES 3
Re: FuzzyLime CMS setup
29-06-2010 4:27 PM
Hi Kevin,
Where are you uploading to (i.e. what FTP address?) and what happens when you try to execute the installation script?
Message 2 of 4
(265 Views)
29-06-2010 5:03 PM
I am uplading the unzipped CMS folder to the htaccess folder.
I can see the file listing from www.mydomain.plus.com/fuzzylime
On this listing i can see the install.php script - When i click it to run however it only gives me the option of saving it - if I navigate it to www.mydomain.plus.com/fuzzylime/install.php I get the script listing displayed but the install does not kick off
Appreciate your help with this.
Message 3 of 4
(265 Views)
29-06-2010 6:31 PM
Unless you have pointed your domain to the CCGI servers you should be uploading to cshell.plus.net and accessing the site via ccgi.mydomain.plus.com/fuzzylime
Message 4 of 4
(265 Views)
