Freenetname/Madasafish/etc. Domain expired, Help!
PSalmons
Hi.
I've just received an email (out of the blue, as far as I'm concerned) to tell me that my domain has already expired and Nominet are in the process of deleting it.  I've had the account doe 25+years and this is the first time I can remember it happening.
Can you renew it for me, or is it something I need to do myself?
Best regards,
Paul Salmons
www.psalmons.co.uk
14 REPLIES 14
Fixes: 579
Re: Freenetname/Madasafish/etc. Domain expired, Help!
Ive escalated this to try and attract staff attention more quickly
PSalmons
Thank you, that's appreciated.
Fixes: 579
@PSalmons the escalation has been picked up. Should be sorted by Monday if not before.
PSalmons
That's brilliant.  Thanks very much for your help.
Best.
Paul.
MickTeer
Hi Mr W,
I have exactly the same problem, and have received a similar message from Nominet. I have a domain <Redacted>.co.uk and two associated emails. <Redacted>@<Redacted>.co.uk and <Redacted>@ madasafish.com I would like to keep the email address associated with the domain. Do i have to get in touch with Plusnet support myself regarding this or can you progress this your self.
Thanks Mick
Moderator's note:
Personal information removed from a public forum (to an area that staff can see).
Fixes: 579
@MickTeer I'll add your domain to the escalation. I'm not sure that contacting support at this late stage will prevent the domain expiring. Even if you get someone in support who understands domains, all they can do is raise a request to NetOPS which can take up to 5 days, by which time the domain will have been deleted
MickTeer
Thanks very much for your help.🤞
Mick
Fixes: 245
@MickTeer
Mick,
Do you have a website on that URL?  MAAF is refusing connections to it.
plusnettony
Fixes: 73
Apologies for the delays, both have been renewed.
 Tony T
MickTeer
Thanks to all who jumped in on this. I am retired but still do occasional engagements so the email associated with the domain is still in use. Seriously impressed with how quickly this was sorted out. 😊
Mick
Fixes: 245
It is indeed amazingly good - weekend SU cover for the escalation and great Plusnet networking in the  background with key players … despite they being on leave.  There’s more dedication around here than many realise.
PSalmons
That's great, thanks very much for your help.  Do you know if this is something that's going to happen to my domain every year now?
Best regards,
Paul.
Fixes: 245
I would not expect so.  The issue which caused this has been flagged for review … and domain management is expected to transfer to Greenby.
PSalmons
Thanks for all your help.
Regards,
Paul.
