Fibre in listed building?
paulh
Currently on "Unlimited Fibre inc. Line rental"
PN keep urging me to upgrade to full fibre, which is cheaper of course.
I'm a renter in a GII listed building, so drilling holes and mounting boxes not only requires my uncooperative landlord to agree but probably requires listed building consent from the local auth which the landlord would have to negotiate.
How does PN handle this sort of thing? There's no guidance whatsoever in the "help".
22 REPLIES 22
Fixes: 580
Re: Fibre in listed building?
Is there any possibility of using an existing copper cable entry point ? and then fitting an internal CSP ?
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to Everything Else
Fixes: 117
@paulh
Can you post a screen image from the following (after hiding your details).
Of particular interest is what is said to the right of WBC FTTP (One Stage or KCI2) and the narrative below the results window.
PhilipHeyes
Champion
Fixes: 19
It might be worth a conversation with the landlord on is there ducting OR can use to run in FTTP to the building, I can understand if there are say 10 units, the landlord is not going to want 10 lots of new fibre runs and 10 lots of damage to the grounds and will not what any let alone multiple fibres on the exterior of the buildings.
paulh
We are sorry but the checker is unavailable at the moment. Please try again later.
Fixes: 117
@paulh
It happens for time to time.
However, the Address version does appear to be working - at least for my address.
Fixes: 117
@paulh
Another matter for consideration is you phone line / service. Do you want to keep it?
PN are actively moving services to EE for those who want to keep a combined internet / phone service or off your current service if either you're happy to lose the phone or prefer to use a VOIP provider.
paulh
Been a bit busy but finally got round to this.
Also, yes, just received the EE migration email but I've no interest in retaining a voice line, so I'll stay with PN.
Fixes: 580
@paulh according to the availability checker , Full fibre is available and you are in a Fibre priority area.
So ordering anything apart from Full fibre is going to be difficult if not impossible!
Openreach know there is 'some' issue as the narrative says 'Complex L2C' (L2C being 'lead to cash' i.e from order to completion)
I'd suggest starting talking to the local authority and the landlord pronto.
I 'think' if you contact Plusnet and tell them its a listed building , then they can get Openreach to come and do a survey and discuss what's possible.
It may be possible to feed the fibre though an existing hole and use an internal CSP which should (hopefully) get around all the listed building issues.
paulh
thanks.
I miss the days when you could go on the PN website, login & "raise a ticket" for q query like this, and then go about your business for the day, rather than sit in a phone queue for 20-30 minutes.
paulh
So that was pretty much a waste of a call.
A survey cannot be ordered in advance.
You have to place an order, and when the Openreach engineer turns up to do the actual installation/upgrade, only then will you know what's required and what permissions you might have to get from landlord, letting agent & local authority.
This must occur reasonably often, surely, there must be processes in place to handle this more elegantly & smoothly?
I live in a location where there's entire streets of listed buildings, it's not a weird one-off thing.
mystreet1
Seasoned Pro
Fixes: 7
This page popped up in a search
https://www.reddit.com/r/openreach/comments/1pi8sx7/openreach_fibre_install_in_grade_2_listed_buildi...
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Fixes: 117
@paulh
As I understand things a survey is done before OpenReach accept the order. For example if digging is required you need to sign off on the job. Likewise if they decide Excess Construction Charges apply you need to accept (or reject) the ECC's.
I think you simply need to place the order and see what happens.
paulh
yeah, that's unfortunately the conclusion I've come to.
It's going to get even more complicated as there are three properties here with a single frontage, and we appear to be supplied from copper coming in off a pole.
