FTTP Static IP Address please
grnglide
Tried to set up Static IP on the web site but it appears not to have worked as others have found.
Can you set this up please. I dont wish the rDNS to point to the Plusnet account user name - just about anything else would do!
5 REPLIES 5
adamwalker
Fixes: 223
Re: FTTP Static IP Address please
Hi @grnglide Sorry about the issue with that, I've hit some problems trying to add a static IP to your account too. Please bear with me and I'll try it again later today for you, failing that I'll need to speak to a colleague when back on shift on the 27th.
 Adam Walker
grnglide
That will be fine, there are plenty of other things going on!
Just noticed that the option to set up a static IP under Add-ons has disappeared leaving only "Plusnet Protect powered by Norton™"
adamwalker
Fixes: 223
Hey @grnglide
I've sorted out the issue with your account and assigned a static IP.
If you restart your router that should assign it to the connection for you.
 Adam Walker
grnglide
Static IP working fine now - thanks.
willcutforth
Fixes: 113
Awesome glad to hear it. Let us know if you need anything else.
 Will Cutforth
