FTP access failing
- Everything else
- Re: FTP access failing
FTP access failing
06-03-2026 4:03 PM
I have been trying to access my webspace over FTP and I get '530 Login incorrect.' As far as I can tell, all my settings in FileZilla are correct, including the account password.
Host: ftp.plus.net
Encryption: Only use plain FTP (insecure)
User: glocal
Password: <password>
Default remote directory: /htdocs
Also, trying to ftp 'ccgi.glocal.plus.com' again fails with '530 Login incorrect.'
Host: ftp.plus.net
User: ccgi.glocal.plus.com
Password: <special password>
These used to work but I haven't logged in to FTP for years. My account password work as normal otherwise, and I tried to reset my 'ccgi.glocal.plus.com' just in case.
Can someone help please.
06-03-2026 4:29 PM
$ lftp ftp.plus.net
lftp ftp.plus.net:~> user glocal
Password:
lftp [email protected]:~> ls
ls: Login failed: 530 Login incorrect.
$ lftp ccgi.glocal.plus.com
lftp ccgi.glocal.plus.com:~> user ccgi.glocal.plus.com
Password:
So, either the passwords were reset or PN has disabled my access.
08-03-2026 12:38 PM
Hi @glocal,
Thanks for coming to the Community!
I'm sorry to hear about the trouble you're having. I know you've mentioned it have been some time since you logged in to FTP. Have you logged in another way more recently?
Rach
08-03-2026 4:57 PM
I can sign in to my broadband account to see my invoices etc using the same credentials (I am signed in now). I can also log in to my default mailbox with the same credentials.
I tried to FTP using FileZilla and lftp on one machine, and an FTP client on Android.
As far as I know, the FTP password cannot be different from the broadband account password. If that's the case, something must have changed with my access at PN's end. Can someone check please. The webpages are still up too.
08-03-2026 6:01 PM
@glocal Were you with force9 originally ?
I've just had the same problem using Filezilla but changing the host to ftp.force9.net it now works............
08-03-2026 6:12 PM
Nope. I've been with Plusnet forever, around 20 years.
08-03-2026 6:21 PM
Thanks for the reply. If the settings work with force9 then it's a Plusnet system configuration problem.
- Everything else
