Domain transfer, IPS tag change
dpevalin
I'd like to transfer my domain out to another provider but i require PN to change the IPS tag, could someone help me with this? @willcutforth
Cheers
7 REPLIES 7
willcutforth
Fixes: 113
Re: Domain transfer, IPS tag change
As if by magic I appear! Just raising a ticket for you and I will pop a link in here so that you can reply to it Smiley
 Will Cutforth
willcutforth
Fixes: 113
https://www.plus.net/wizard/?p=view_question&id=235165746 is the gateway
 Will Cutforth
dpevalin
Cheers Will you're a
willcutforth
Fixes: 113
All raised up now for you Smiley Give it 72 hours, however it is usually done before then.
 Will Cutforth
willcutforth
Fixes: 113
All sorted now for you Smiley Looking ok from your side?
 Will Cutforth
dpevalin
All working perfectly, thanks Will.
willcutforth
Fixes: 113
Awesome. Let us know if you need anything else.
 Will Cutforth
