Domain Transfer
mjcuk
Domain Transfer
I am looking to transfer my domain away from Plusnet to another registrar. To do this, I believe I need to post here to ask someone from the Plusnet team to raise a ticket on my behalf.
Could I please get a ticket raised for this?
Thanks!
7 REPLIES 7
willcutforth
Fixes: 113
Re: Domain Transfer
@mjcuk Popped you a text message over to get this sorted Smiley
 Will Cutforth
mjcuk
Re: Domain Transfer
Thanks Will.
Do you mean that you sent an SMS on my mobile? I didn't receive anything but it looks like I had an old number on my account, I have updated it now if you want to try again.
adamwalker
Fixes: 223
Re: Domain Transfer
Hi there, no we'd usually send you a PM on here, please have a look at your inbox and you'll likely have a message from Will.
Adam - Plusnet Sheffield
 Adam Walker
mjcuk
Re: Domain Transfer
Thanks. I checked my private message but there doesn't seem to be any messages in there.
James30
Fixes: 32
Re: Domain Transfer
Please can you reply to this ticket instead @ https://www.plus.net/wizard/?p=view_question&id=243154207
James - Plusnet Sheffield
mjcuk
Re: Domain Transfer
Hi @James30
Could you please check the status of this transfer? I received a reply in the ticket saying that it would be actioned but more than 5 working days have past and the transfer doesn't appear to have happened.
MatthewWheeler
Fixes: 503
Re: Domain Transfer
Hi @mjcuk
I've checked and the request is still with the right team.
Unfortunately there's a bit of a backlog but it should be picked up soon
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
