Does Hub Two work with Voip?
HPsauce
All Star
Fixes: 5
Re: Does Hub Two work with Voip?
You can do a reset via the management menus, but also externally as follows:
  1. Unplug the base from the power source (either the plug or the ethernet cable if you are using PoE)
  2. Hold down the soft button on the front of the base and reconnect the power. Keep the button held down until the blue light flashes rapidly for twenty seconds then release it
  3. Your base should now be reset
Fixes: 580
@HPsauce now I didn't know about the external reset😀
Reading the manual, it says that the reset via the management menus doesnt de-register handsets BUT the external one via the button does. So it's probably preferable to do the external one.
HPsauce
All Star
Fixes: 5
Well spotted @MisterW I missed that detail; I'd advise @Frances28 do both to be sure. You'd need the button reset anyway if you don't know the access pin.
"Reading the manual, it says that the reset via the management menus doesn't de-register handsets BUT the external one via the button does. So it's probably preferable to do the external one."
Frances28
I've got a litle way but I can't see how to register my handsets. I have a Panasonic KX-TG1311E handset and I think I've deregistered it . The N300 controls say no handset assigned.
Fixes: 580
The details on how to register that handset to a base are on page 21 of the handset manual
Follow that procedure and then when it says 'Press and hold {x} on the base unit for about 5 seconds' , Press and hold the button on the front of the N300.
NB make sure that the Panasonic base is turned off so the handset doesnt find that base
HPsauce
All Star
Fixes: 5
You need to find the menu option on the handset to register, put the base into registration mode (Management menu, Miscellaneous) then try to register. Handset should ask for a PIN.
Frances28
Thank you for this. I have 3 handsets and have managed to register one with the N300 (I don't really know how!). The other two have run out of battery so I have to charge them on a plugged in base set before I can try to register them. Hope you don't mind another question - I'm following the A&A instructions for setting up the N300 but I've got 'registration failed' against the IP1 line. Is this serious? Also, it tells me to put Your Password against Authentication Password. I have two A&A passwords, SIP password and Control Page login password. Is it one of these and if so which one? I've tried both and still have registration failed.
Thanks in advance!
mystreet1
Seasoned Pro
Fixes: 7
Have a read of this from A&A
https://support.aa.net.uk/VoIP_Phones_-_Gigaset_N300
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Fixes: 580
@Frances28 it's the sip password. You may find that you to set a new one first using the control pages and then use that
Frances28
Thank you
Frances28
So now it's registered and I can divert calls to my mobile . But the Panasonic isn't ringing (maybe I've not set that up but not a problem). I think I'll call it a day and thank everyone for their help. I might be back but will probably live with it as it is.
Thank you all.
Fixes: 580
@Frances28  login to the n300 and go to Settings>telephony>number assignment and make sure that the handset has a tick in the incoming calls column for that a & a connection
HPsauce
All Star
Fixes: 5
@Frances28 I've sometimes noticed the N300 can say connections aren't registered when they are, just refreshing by navigating away and coming back usually shows the correct status.
As you're discovering, it's a whole new world with different concepts and doesn't have the simplicity of old-school telephony, but hopefully you get used to it in the end. Once set up it just works OK. Definitely explore all the menu options both on the N300 but also within A&A, especially the control pages. Emailing answerphone messages I find particularly useful.
Also, in due course you may find, as I have, that old DECT handsets are rather limited and decide on compatible Gigaset ones which have full functionality. But equally you may not, especially if you get very few incoming calls.
RobPN
Fixes: 15
@HPsauce
You don't need to navigate away and come back, just click the 'Set' button and the page will refresh. Wink
Frances28
It's finally working! Interestingly only once I had registered all three handsets. As soon as no. 3 was registered I got a dialling tone and can make and receive calls. I'm pleased that I don't have to spend any more time on it and thanks to all once again.
