Does Hub Two work with Voip?
mystreet1
Seasoned Pro
Fixes: 7
Re: Does Hub Two work with Voip?
@Frances28 glad that everything has worked out for you and working as you want it.
It has been a good learning tools for some of us about the hardware we are using N300ip.
Just one more tip that I found. Type https://www.gigaset-config.com/ in you browser will list the hardware on your local network which you can then select. No looking in the hub for the ip address.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Fixes: 579
@Frances28 Glad its all working for you
RobPN
Fixes: 15
@Frances28 wrote:
It's finally working! Interestingly only once I had registered all three handsets. As soon as no. 3 was registered I got a dialling tone and can make and receive calls.
@Frances28
Using only Gigaset handsets here, I'm wondering if that dial tone is handset dependent - can you now hear dial tone on handsets #1 and #2, or is it only on #3?
I ask because I don't normally hear dial tone before dialling. The only time I recall hearing dial tone is if I use the 'Select Line' function to use, say the landline, instead of just allowing the dial plan to route a call over the appropriate VoIP 'line'.
Frances28
When I press the pick up/ make a call button on each phone I get the dialling tone. Not when I just lift them off the base.
I think I'd decided to get new phones because some of the buttons are a bit dodgy, but I'm not going through this all over again!
Next task is to record my own voicemail message, which I think I know how to do.
HPsauce
All Star
Fixes: 5
I'm another one that abandoned my old, failing DECT handsets and am now on Gigaset ones which work differently so you only hear dial tone (briefly) once a number is entered/chosen and the call is initiated.
I can't honestly remember how my old handsets worked, some I think had auto-answer on so you just lifted them to answer an incoming call, but none IIRC would give you outgoing dial tone unless you pressed a relevant button.
Note that with A&A the BT-style 17070 number works and is free and tells you your number, no testing options.
Fixes: 579
For anyone looking for additional Gigaset handsets and living near Bracknell , bit of a bargain here https://www.gumtree.com/p/other-home-phone-accessories/gigaset-s850a-go-pair-of-cordless-phones/1474...
