Correcting a PTR record
Capital
By default, Plusnet assigns my username to my fixed IP in the PTR record, i.e. username.plus.com.  I have a mailserver attached to this IP.  Can I change the PTR value to my FQDN?  Does anyone know how this can be done?
6 REPLIES 6
Fixes: 583
Re: Correcting a PTR record
@Capital Yes, you ask here, and one of the staff will pickup the request and ask for confirmation.
Assuming you already have a forward pointing A record to your FQDN, then the rDNS PTR can be set to that.
Capital
Thank you MisterW.
My FQDN is [Removed]
I confirm that I have a A record in my DNS table for exactly that value.
Thank you.
Moderator's note by Mike (Mav): Personal information removed from a public forum (to an area that staff can see).
Fixes: 583
I'd edit your post to remove the FQDN , this is a public forum. Staff will ask for the details either in a PM or by a ticket on your account.
willcutforth
Fixes: 113
@Capital I have popped you over a text to sort this. I hope this helps.
 Will Cutforth
Capital
Hi @willcutforth ,
I have resolved the problems with my mailserver, so can we pick up the issue of my PTR record please?
Tina11192
Fixes: 18
Hi @Capital thank you for getting in touch.
I tried searching for your account using your email address, however, I wasn't able to locate it.
At your earliest convenience, please direct message me with the Plusnet username so that I can raise this off to our NetOps team.
I look forward to hearing from you soon
Cri Ignatti
