Confused about FTTP availability ?
Fixes: 391
Re: Confused about FTTP availability ?
OK - I understand that, but if the manholes have been marked, they are - hopefully - doing he survey work.
Fixes: 118
@PH63
I'd keep an eye on questions on your PN account. You should get emailed of developments but you never know.
The lack of detail about an FTTP install on the Checker results is unhelpful. I'm wondering if digging is required from the manhole to your external wall. Can you post an image or the manhole? OR manholes are not usually 30m apart - UG chambers are about 100, apart on my street.
PH63
@bmc
I did some snooping up and down the road and I'm fairly sure that at least two properties on the same side of the street as mine have in fact got FTTP connections ! (now I know what to look for). You are correct though that there was obviously some digging involved to bring the fibre from the nearest manhole to each house. They also look like fairly new additions as the tarmac is still fresh. Anyway, this discovery makes me think that it's fairly certain that I will be able to obtain FTTP and I'd just like to thank you and everybody else for their input. Cheers for now, hopefully I will update on Dec 2nd Smiley
Fixes: 118
@PH63
A picture of the manhole would still be helpful. I'm thinking it's what's known as a "TobyBox"
If you look at the Checker mentioned in post #2 for the Addresses you think might have FTTP it'll tell you (or at least it should) if an ONT is installed.
PH63
@bmc
I just looked at one of the houses I'm 99% certain already has FTTP and the status says 'Available' and 'KC12 Assure' under the FTTP Install Process. Guessing it only gets updated when people actually move to FTTP ? Either way it does look like it's physically available (with some digging perhaps).
Fixes: 118
@PH63
KCI2 means a survey is required - hence the request for photos and a video I suspect. Almost certainly it means digging a trench from the nearest chamber to your house.
This might tie in with your previous comment about the install being on the 1st with completion on the 2nd. Dig one day and install the next. An installation is normally completed on the day. The engineer will plug their computer into the ONT and run a test (I believe) and then, if happy, plug your router in to confirm it's working for you before they leave.
Have another look at the Checker results you looked at previously. Below the results window should be a narrative on FTTP and the install. It'll state if an ONT is present and / or if any potential problems have been noted (like having to dig a trench).
Fixes: 480
@PH63
The  Availability Database is updated as and when, it is not related to whether Full Fibre has been installed in a property. KCI2 means that installation is a 2 part process. Openreach will come and survey the route, a dig team will come and install a duct across your front garden and then another technician will install the fibre. This will not all happen on the first visit.
Fixes: 391
@bmc The checker result the OP posted has nothing about FTTP in the narrative.
Fixes: 118
@jab1
The OP since looked at one of his neighbours who they believe has FTTP - it showed Available and KCI2
Fixes: 391
I am aware of that, but as to his property...
Fixes: 118
@jab1
I was asking about his neighbours property as it might give a clue to his own situation.
PH63
@Baldrick1
Ahh, thanks, that makes sense. I should be off both days so it's not an issue either way.
