Cannot access my Website
- Everything else
- Re: Cannot access my Website
15-01-2017 8:02 PM
I cannot access my website. I am getting message #403 "No permission - forbidden". I suspect that my website was infected by a virus recently, but I have erased all data and uploaded new stuff. How can I remove the "no permission" and regain access to my website?
16-01-2017 10:17 AM
What type of website is it ? Wordpress etc ?
16-01-2017 11:53 AM
I wrote it myself in HTML and uploaded to webspace given to me by Plus Net when I signed on. I did not access it for a long time and when I tried to access it a few days ago a pop up blocked it. The pop up was from CSVERT.IN . I could not even see the source code because it would appear withing 2 - 3 seconds. I downloaded the Index.html, found CSVERT.IN script and erased it before uploading it back to my webspace. That stopped the pop up, but soon after I was locked out. I have since erased everything on that website and uploaded completely new stuff, but the "Forbidden - no permission to access" persists. Does this gives you the info. that you wanted to know? Many thanks. Alex
16-01-2017 10:26 PM
Please advise as to what ftp program you are using for further help.
17-01-2017 12:28 AM
I used Windows10 FTP by Adding Network Place in File Explorer. That has worked in the past, but I had problems when I tried to delete everything and start again - it would not delete. So, to delete all previous files I used gFTP running in Puppy Slacko, running off an USB stick. I have just deleted all files using gFTP and then uploaded just Index.html and I am still getting error 403. If you think that using Win10 and Linux is a problem (it never was before) I can delete all files and then use whichever FTP you think would get me out of this. Thanks for your help. Much appreciated. Alex
17-01-2017 3:10 AM
I'll have to check back on the exact permissions required, as like you I've not touched our web space stuff in a long time.
17-01-2017 9:44 AM
As @RPMozley has already mentioned, I also suspect that this is a file permissions issue. You will need to amend the permissions on the website files so that users viewing the file have 'read' permissions. You can do this by using a more advanced FTP (like FileZilla) that can apply permissions to files (via the CHMOD command) on the server or when they get uploaded.
A quick google search gives this guide that seems to have all the info needed: http://www.dummies.com/web-design-development/wordpress/navigation-customization/how-to-change-file-...
As an aside, this issue stumped me a few years ago when I uploaded a php website to my AWS virtual machine and I received a 403 forbidden message too. Applying the correct permissions to the entire folder worked as it was basically telling the web server that it was okay for anyone to 'read' the files when visiting my website URL. The permissions were set as DENY on that so the server refused to let me (and anyone else) see the website working.
I hope this helps.
17-01-2017 2:55 PM
Have you made sure there aren't any hidden files (which start with a full stop) left in the directory? Specifically .htaccess which might have directives denying access to the webserver? Many FTP programs by default don't list hidden files; in these cases there is usually a settings option to list them. For example in FileZilla the last option on the Server menu - Force showing hidden files - needs to be ticked.
Hidden files need to be transferred in ASCII mode to ensure line endings are managed correctly. The best way to handle these is usually by renaming them to htaccess.txt (without a leading dot) and transfer the renamed file. Windows doesn't handle files with names starting with a dot gracefully.
HTML files and text files need to be transferred in ASCII mode, images in binary mode.
Website files uploaded to the server should go into the /htdocs folder. Files should have file permissions (octal) 0644 (-rw-r--r--) and directories 0755 (drwxr-xr-x).
17-01-2017 3:29 PM
Guys, I cannot thank you enough for all the information and advice. I do not have FileZilla, but i will download one and use it. I will report back in a few days.
Thanks again,
Alex
18-01-2017 9:33 PM
I downloaded and FileZilla last night and changed permissions to htdocs to 0755 and to 0644 to other files. I got full access instantly. You are right RPMozley, the website is very old. Written in the days before digital cameras and abandoned when original host, Freeserve, stopped hosting it. It contains CGI-bin mailform, which I understand Plus net does not operate, so I did not update. I don't know why the permissions were changed, but I followed David's instructions and all is well now. I shall keep FileZilla - thank you jared83 for recommending it.
I am really grateful to you all for help.
Alex
19-01-2017 9:18 AM
I am glad that we were able to help in some way and you have now got access to your website back again!
Let us know if you need any advice with anything else at all
- Everything else
