Can I have my Hub Two Router sent to another address rather than the billing address ?
endlesshurdles
 I don't want my Hub Two Router sent to my billing address (where I live) because I live in a block of flats and the
letterboxes are all in the front wall and have very narrow openings. Is it possible to have it delivered to my work address
or my parents address?
1 REPLY 1
bobpullen
Fixes: 330
Re: Can I have my Hub Two Router sent to another address rather than the billing address ?
Yes, this is possible.
I've dropped you a Private Message. If you can reply to it with the details I've asked for then I'll get this sorted for you.
