Can I have my Hub Two Router sent to another address rather than the billing address ?
- Everything else
- Can I have my Hub Two Router sent to another addre...
08-05-2023 11:04 AM
I don't want my Hub Two Router sent to my billing address (where I live) because I live in a block of flats and the
letterboxes are all in the front wall and have very narrow openings. Is it possible to have it delivered to my work address
or my parents address?
Message 1 of 2
(736 Views)
1 REPLY 1
Re: Can I have my Hub Two Router sent to another address rather than the billing address ?
09-05-2023 6:56 AM
Yes, this is possible.
I've dropped you a Private Message. If you can reply to it with the details I've asked for then I'll get this sorted for you.
- Everything else
