CGI shell access disabled 17/08
- Everything else
- CGI shell access disabled 17/08
17-08-2009 10:43 AM
[quote author="Service Status"]When's this work happening?
Today
What does it affect?
Shell access to our CGI hosting platform.
How long will it take?
We will announce further details regarding restoration of the service at a later date.
What does the work involve?
We are disabling SSH and telnet access whilst we investigate a recently identified problem with the platform.
Is it likely to cause problems?
Yes, you won't be unable to access the CGI platform via command line until further notice - http://usertools.plus.net/tutorials/id/18
Is there anything else I need to know?
You will still be able to access the platform using FTP and customers' websites will still be viewable via HTTP. We will post another announcement once we're in a position to be able to restore full access to the platform.
Kind Regards,
Customer Support
Re: CGI shell access disabled 17/08
17-08-2009 3:11 PM
Customer and Forum Moderator. Windows 10 Firefox 100.0.2 (64-bit (64-bit)
19-08-2009 9:36 PM
best wishes,
Doug
22-08-2009 10:46 PM
Quote from: Bob We are disabling SSH and telnet access whilst we investigate a recently identified problem with the platform.
I'd appreciate some help from anyone who has been able to populate a mysql table from a txt file (not csv) without using shell access.
About a year back, Kev Mawson kindly gave me the path for doing this on PAYH -
Quote LOAD DATA LOCAL INFILE '/var/www/vhosts/domain name/httpdocs/CHINESEtcvocab03.txt' INTO TABLE VOCABchinesetc01;
but I haven't yet been successful in executing any address-variables of such a query in the outer-database area of PHPMyAdmin, on the Force9 ccgi server.
I can import a csv file when a table is open (utf8, using CSV LOAD DATA) but all the data goes into the first column, generally (though some of the options cause it to go onto the full number of lines). I've tried numerous combinations of 'options' but nothing works as simply as a txt file imported via telnet (using a LOAD DATA LOCAL INFILE 'nameoffile.txt' INTO TABLE nameoftable; type of request).
Logic says there must be a direct filepath via which a txt file can be loaded (using php myadmin) into an emptied table, but I haven't been able to locate it and running out of time here. Currently need to populate tables for Indonesian, Urdu and Bulgarian, amongst others. I've uploaded the txt file to ccgi (Force 9) but I don't know how to tell mysql where it is (and have also tried a number of prefix variables like /files/home1/username/ without mysql having been able to locate the file). Haven't replicated things like the httpdocs in the original example because assume doesn't apply on ccgi.
Running out of ideas ^^ Any help would be much appreciated.
Regards,
Penny.
Project HappyChild - free worksheets, maths, languages, spellings, all sorts - page *here* re linking languages across the world - see also the freeway page
23-08-2009 1:06 AM
However I think running the command within a PHP program on CCGI should work.
The steps would be
(1) FTP the text file to the same directory as the PHP program
Within the PHP program
(2) Connect to the database
(3) $load_query = "LOAD DATA LOCAL INFILE 'nameoffile.txt' INTO TABLE nameoftable";
(4) $result = mysql_query($load_query);
(5) if ($result) {echo "table loaded successfully";}
else {echo "loading failed< br / >\n", mysql_error();}
Run the program in the browser as for a normal PHP program.
David
23-08-2009 2:50 AM
Quote from: spraxyt I'm not sure that can be done within phpMyAdmin since I think "local" would refer to the MySQL server which is probably not the one where the file resides.
Sheer genius
Barely ten minutes from reading your post, the data was loaded. Thank you sooo much.
I would probably never have thought of positioning the query where the txt file was located, rather than its intended destination. Entirely logical, though, thinking about it. Not that I would have known how to construct that query, either
Really appreciate your help.
Penny.
24-08-2009 10:37 AM
Rgds,
Dave Hennings.
24-08-2009 11:25 AM
24-08-2009 11:34 AM
25-08-2009 9:09 AM
25-08-2009 9:18 AM
25-08-2009 11:11 AM
25-08-2009 11:14 AM
25-08-2009 11:37 AM
25-08-2009 1:14 PM
Until now I've used MySQL Administrator & MySQL Query browser, I was going to give you the link and found it had been replaced by Workbench. I assumed it would work in a similar way. I've now downloaded workbench and seen your problem. Time for some research!
- Everything else
