DNS, ccgi and sub-directories.
- Everything else
- DNS, ccgi and sub-directories.
05-09-2009 3:05 PM
Hello. I have a domain (whatbots.com) that uses the Force 9 names servers (NS1.FORCE9.NET. NS2.FORCE9.NET). At present whatbots.com "points to" http://www.ponds.f9.co.uk/whatbots/index.html .
This website looks awful and I re-worked it to use PHP/Wordpress/Revolution theme. The re-worked website is at http://ccgi.ponds.force9.co.uk/whatbots/
I was hoping to switch it so that when you go to www.whatbots.com, you would go to the reworked ccgi site and not the old one as you do at present.
I thought I would just be able to get Force 9 to point to the http://ccgi.ponds.force9.co.uk/whatbots/ and raised a ticket to get this done. It seems from the response to the ticket that this can't be done and that they can only point at my root directory - i.e. http://ccgi.ponds.force9.co.uk/ ; This seems restrictive, as it seems if I want to do this, I can only ever have one cgi application. Is there a way round this or have I misunderstood something?
I hope I've used the right terminology to describe this. Thanks for any ideas.
Message 1 of 2
(1,807 Views)
1 REPLY 1
Re: DNS, ccgi and sub-directories.
10-09-2009 10:24 AM
Hi Brian,
If we point the domain to your ccgi space using DNS records, it would only point to the root folder in ccgi. To get around this, please check the link below:
http://community.plus.net/forum/index.php/topic,71173.msg564931.html
Message 2 of 2
(270 Views)
- Everything else
