Bit Torrent
jamsey66
Bit Torrent
Is PN restricting access to torrent sites, asking for a friend 😇
27 REPLIES 27
Fixes: 388
Re: Bit Torrent
Not so far as I'm aware, so long as they are legit.
RobPN
Fixes: 15
Re: Bit Torrent
AFAIR the larger ISPs in the UK restrict access to certain BitTorrent sites which were named in court orders several years ago.
You can access them via a VPN to download the small .torrent file, then once you have that, you can switch the VPN off if you're using a free one which is slow or has limited usage, and then carry on to download the main files using your normal connection.
You may find some blocked ones which you can access by changing your DNS IP addresses.
So a friend of mine tells me. Wink
Fixes: 1,495
Re: Bit Torrent
Moderators Note
This topic has been moved from Broadband to Everything Else
Rgmanby
Re: Bit Torrent
Exactly what I do for yifi, use mobile either Vodafone or giffgaff to download magnet then swith to WiFi for the rest.
My pirate bay isn't blocked though, just yts?
jamsey66
Re: Bit Torrent
My friend was accessing them a couple of days ago no problems at all, all he gets now is a privacy page if he says access site it’s just a blank screen, hopefully someone has some ideas
Fixes: 388
Re: Bit Torrent
Which site?
jamsey66
Re: Bit Torrent
PB and EZTV
Fixes: 388
Re: Bit Torrent
If PB = Pirate Bay, they are banned under a court order, and ISPs are legally required to block them. No idea what ESTV is.
BTW Do you mean 'Piracy' rather than 'Privacy'?
Browni
Aspiring Hero
Fixes: 61
Re: Bit Torrent
EZTV is on the list of blocked sites.
Full list here.
Fixes: 388
Re: Bit Torrent
Cheers, @Browni , so @jamsey66 's 'friend' is trying to access legally blocked content.
Rgmanby
Re: Bit Torrent
Fixes: 388
Re: Bit Torrent
Weirdly, I can get to the main page, which I find strange as I understand they re blocked by court order, but I wonder if it is because my ISP is not named in the order? I'm going no further than the 'Home' page, though.
RobPN
Fixes: 15
Re: Bit Torrent
@Rgmanby wrote:
My PB works fine?
https://thepiratebay.org/index.html
Likewise.
Rgmanby
Re: Bit Torrent
It's only illegal if you download copyrighted material.
There are lots of bands, devs and amateur film makers who upload their stuff there for free, like github etc, just be careful you only download non copyrighted material.
