Bit Torrent
Browni
Aspiring Hero
Fixes: 61
Re: Bit Torrent
@Rgmanby which DNS servers are you using?
I can access the Pirate Bay even though I am on BT. I am using Cloudflare DNS though.
Rgmanby
Re: Bit Torrent
I'm just using PN through pi-hole.
Fixes: 388
Re: Bit Torrent
@Rgmanby wrote:
It's only illegal if you download copyrighted material.
There are lots of bands, devs and amateur film makers who upload their stuff there for free, like github etc, just be careful you only download non copyrighted material.
Fair enough, but I'm still steering  clear.
Fixes: 388
Re: Bit Torrent
@Rgmanby I use github, but only for computer programs - from reliable links on sites I trust, or recommendations from trusted sources.
Rgmanby
Re: Bit Torrent
That's where all my flash roms for STC12c come from too, it really is a good resource for dev's, some clever people out there 👍
jamsey66
Re: Bit Torrent
apparently it came up with SSL Cert error (privacy)
jamsey66
Re: Bit Torrent
fixed now, changed dns, rebooted hub all working
IronMonk1
Re: Bit Torrent
My friend has noticed this in the last couple of days. Torrent sites flag up the unsafe site page from my browser. When you accept the risk and continue to the site it just displays a blank page. Happens no matter the browser I use or if it's updated. Could only be the ISP? Plusnet introducted a new setting?
Fixes: 388
Re: Bit Torrent
If they are blocked due to a court order, the ISP is obliged to refuse connection.
IronMonk1
Re: Bit Torrent
Surely all those would have been in place years ago. Seems a bit strange all of a sudden with no recent news to suggest why and also not much chatter about it. Best I could find was a trade deal with Australia re-inforcing protection of intellectual property.
Mustrum
Fixes: 81
Re: Bit Torrent
@IronMonk1  That sounds more like a security system setting or anti virus program on your device. Have you changed or checked that, or tried another known working device?
IronMonk1
Re: Bit Torrent
It did the same on other devices and with firewalls etc switched off. However as mentioned earlier changing the DNS service worked. Can't put a finger on why it suddenly didn't work beforehand. I googled the IP his router was using for the original DNS and while not an exact match, it was mentioned in this thread which goes over my head. Probably unrelated.
https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Has-Plusnet-server-212-159-6-9-just-go...
ModelCitizen2
Re: Bit Torrent
Someone should probably tell Google as PB is available if you use their DNS servers. (That's 8.8.8.8 and 8.8.4.4 btw.)
