Bb line number
pvmb
Champion
Fixes: 17
Re: Bb line number
...Still waiting, so no final report!
So it half works. Putting it another way: it doesn't work. Oh well. ☹️
Tags (1)
Fixes: 251
Re: Bb line number
What are you expecting to happen here?
You’ve invoked the PHONE bot referencing your mobile number.
The original implementation did require the telephone number on which Plusnet’s service is provided, however that functionality has changed. Now you text..
PHONE for a voice service fault
HELP for a broadband fault
ADVISOR to request a support call
What service fault are you seeking assistance with?
Tags (1)
pvmb
Champion
Fixes: 17
Re: Bb line number
Success! It DOES work...
Overnight  - I got a report in the morning. To be fair I turn my mobile off overnight and got the report in the morning. No fault found, offered to carry out further tests if I replied "NEXT", which I did but likely my test had timed out by then. Bot replied I could text "ADVISOR" during working hours for them to call back.
So the initial response to the test request was quick, much quicker than the "within 15 minutes". But the test report took longer than the reported "within 30 minutes", I don't know how long.
So automatic circuit test works for me using my mobile number for the test line - I am on FTTC and still with a landline phone.
Tags (1)
