Is there a current problem with Usenet?
BertCoules
Both yesterday and today I've had very patchy connection to Usenet, with brief periods where everything was OK and much longer ones with no connection at all.  As I type this (19:14 on Sunday 24th November) the service is down.
Since my setup is working properly some of the time, I suspect that the problem doesn't lie at my end - but can anyone please confirm that?
I'm using Thunderbird 128.3 running on a Windows 10 desktop PC.  The email side of the program is fine, even when the Usenet connection is down.
Many thanks.
8 REPLIES 8
Re: Is there a current problem with Usenet?
I haven't used or tried usenet in many a year, but I successfully telneted to port 119 using hostname usenet.plus.net and got a reply from giganews.
(I'm on a fullfibre connection, and any info relating to usenet for that sort of account doesn't easily appear on the PN website)
I did however stumble over a bit of the community website that appears to not be linked into the forums. Plenty of broken weblinks there IMO.
https://community.plus.net/t5/Library/bg-p/library
"USENET continues to be a popular place for veteran Internet users"
Fixes: 388
From a 2015 post?
BertCoules
Grumble, thanks for that.  So perhaps the fault is at my end, though I can't think what it might be, given that I changed nothing between the bouts of the connection working and it not working.  More investigation is required, clearly.
BertCoules
As of this morning, it's working again.
BertCoules
...But not for long.  On-again, off-again several times today.
Quelle surprise!
I successfully telneted to port 119 using hostname usenet.plus.net and got a reply from giganews. Again.
But that's just me.
It turned up on a web search.
