Bb line number
Megawrecker
Bb line number
How do you text fault to plusnet if you don't have a landline
Tags (2)
17 REPLIES 17
Fixes: 254
Re: Bb line number
You text from your mobile phone ... texting from a landline requires atypical capability.
Fixes: 118
Re: Bb line number
@Megawrecker
If you'e on SOGEA (no landline) or FTTP then I believe the TEXT link doesn't work - it need's the landline number.
You either have to phone support or wait until a staff member picks up this thread - as they tend to be thin on the ground this could be days.
Megawrecker
Re: Bb line number
Thankyou
Megawrecker
Re: Bb line number
When i text fault on mobile it comes back as number not recognised
Fixes: 392
Re: Bb line number
Have added it to your account?
Fixes: 118
Re: Bb line number
@Megawrecker
Stupid question time - did you text "HELP" as per the support page?
@jab1
If the OP is on SOGEA or FTTP then there is no landline number to add to the account.
Fixes: 392
Re: Bb line number
@bmc Maybe I wasn't clear enough, @bmc - I meant the mobile number, I am well aware that SoGEA/FTTP connections do not have a land-line number.
Fixes: 118
Re: Bb line number
@jab1
As far as I'm aware the mobile number doesn't work either.
Fixes: 392
Re: Bb line number
I had heard that rumour, although  some seem to succeed. The only option in that case is to call.
Fixes: 254
Re: Bb line number
I have an escalation on this - if I understood correctly if the mobile is referenced on the account it should work.
Fixes: 118
Re: Bb line number
@Townman
iI was considering asking for an escalation on this. It's not the first time this question has been asked on here.
PN need to change the wording on their Support page to state either that texting "HELP" doesn't work on SOGEA or FTTP or. if it does work with mobiles then the number needs to be added to a Users account in both the landline and mobile numbers.
pvmb
Seasoned Champion
Fixes: 17
Re: Bb line number
Surely what needs to be done is for Plusnet to get the system to work with the BBEU number, instead of a landline number?
After all, in future, nobody will have a 'landline' number...
Fixes: 254
Re: Bb line number
Complete misunderstanding - the issue is (without the addition to the text message) to map the mobile phone number to the account name. Nothing to do with the supply phone line or the BBEU number.
pvmb
Seasoned Champion
Fixes: 17
Re: Bb line number
@Townman
Finally... I am in the process of trying this out for myself.
Texting "PHONE <my mobile number>" to number 07800 008121
So far it looks as if is working (got last three digits of my postcode). Eureka! But still waiting for the final report.
