Basic Help
- Everything else
- Basic Help
Basic Help
05-09-2010 10:54 PM
I'm totally new to PHP so this is probably a very silly question but.... I have some PHP code so that part of writing the code has been done and I use the code elsewhere without issue. I wish to host the code on my plusnet webspace and customise it my way. I have enabled both the mysql database and the CGI section. I can login to MYSQL using the https://portal.plus.net/tools/phpmyadmin and all looks good. The problem I have is I cannot login into my CGI webspace to upload the various files and configure the permissions. I have tried http://ftp://cshell.plus.net/ and the login fails. I have tried:
It seems like a very simple question but I can't seem to figure it out, any help will be gratefully recieved.
C:\Users\Bomber>ftp cshell.plus.net
Connected to cshell.plus.net.
220 Plus.Net CGI FTP Server #2 ready
User (cshell.plus.net:(none)): thompson73
331 Password required for thompson73.
Password:
530 Login incorrect.
Login failed.
ftp> bye
221 Goodbye.
C:\Users\Bomber>
Message 1 of 2
(645 Views)
1 REPLY 1
Re: Basic Help
05-09-2010 11:55 PM
When you activated your CCGI you should have received an email detailing the login and password to use. If I remember this is different to your normal portal login details.
If you don't see an email just disable and re-enable the ccgi component on the portal and wait for the email. If you don't receive it within a day raise a ticket.
Message 2 of 2
(107 Views)
