Any PHPBB/Database Experts Out There?
- Everything else
- Re: Any PHPBB/Database Experts Out There?
15-01-2015 11:42 AM
phpBB : Critical Error
Could not query config information
DEBUG MODE
SQL Error : 1033 Table './theadamsons_f9_ccgi_theadamsons_force9_co_uk/phpbb_config' was created with a different version of MySQL and cannot be read
SELECT * FROM phpbb_config
which seems pretty self-explanatory but is it fatal or fixable? If I can fix it how? And do I need to tidy the database up anyhow?
Its actually for a club that I no longer belong to I haven't bothered to check recently.
15-01-2015 12:09 PM
Should be fixed now.
I'm not sure what happened but your bulletin board was pointing to a MySQL 4 instance of your database. It's possibly been broken since the migration of your site to the Hostopia CGI platform last year.
I've updated the host name in your config.php file and commented out the line that was causing the problem.
Take a look and you should see what I mean.
15-01-2015 12:19 PM
Actually this is the first time I've looked at it for nigh on a year after I was prodded by someone at my old club. I'm not sure if even they have been using it recently or not as I no longer belong to it. So heaven alone knows when it was last definitely working. I'm sure it worked OK straight after the migration though. Has anything changed since then (possibly a silly question ;)).
Ccgi has been on a bit of a back burner. This has prompted me to pull one of my fingers out
15-01-2015 1:57 PM
Ah well - no problems, thanks for fixing it.
01-02-2015 1:21 AM
The config file conf_global.php seems to have been modified with the correct settings inputed but it still won't connect, any ideas?
01-02-2015 8:07 AM
Generally there isnt an issue when upgrading mysql, but possible issues may occur if the admin of the server doesnt follow proper procedures such as running the mysql-upgrade script following an upgrade.
02-02-2015 1:02 PM
Quote from: SiMania I have a similar problem, my Invision board stopped working at the changeover and I've been asked my the members to look at fixing it a year on, it's http://ccgi.simania.plus.com/forums/
The password in the config file wasn't being recognised. This was evident when trying to use the SQL Manager in the Hosting Control panel to log into your database.
I've reset the password to match the one in your config file, however this has introduced another problem with one of your SQL statements. Unfortunately, it's not obvious to me what's causing this error.
02-02-2015 2:55 PM
02-02-2015 4:34 PM
- Everything else
