Activate Static IP
mxtte
Activate Static IP
Hello,
I’ve recently had my line activated and added on a static IP. When I go to My Account and try to activate it, the button doesn’t appear to do anything & it continually shows “You are using a dynamic IP.”
According to this thread - https://community.plus.net/t5/Everything-else/Can-t-enable-static-IP/m-p/1924177#M31428 - it’s been busted for a while.
Could someone from PN be kind enough to activate on my behalf?
Thanks,
Matt
4 REPLIES 4
Fixes: 480
Re: Activate Static IP
Moderator's note:
Thread moved from Broadband to Everything Else
MatthewWheeler
Fixes: 503
Hi @mxtte
That should be sorted for you now.
If you reboot your router you'll pick the static IP up
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
ultrasbm
Hi @MatthewWheeler
I too have the same issue. The button does nothing for me at all - just refreshes the page.
Could you activate it for me also please?
<Redacted>
Thanks!
Moderator's note:
Personal information removed from a public forum (to an area that staff can see).
James30
Fixes: 32
@ultrasbm - Sorry for that, sorted it out, just reboot the router. I've left you a ticket detailing it all here @ https://www.plus.net/wizard/?p=view_question&id=240811836 .
James - Plusnet Sheffield
