ADSL Golden Ratio
Leapy
Seasoned Champion
ADSL Golden Ratio
Is there such a thing as an ADSL Golden Ratio?🤔
I ask as there seems to be some form of correlation in that the up speed seems to be around a fifth of the down speed. 🙂🙄
6 REPLIES 6
Legend
Fixes: 255
Re: ADSL Golden Ratio
@Leapy I dont think so, but there is a max upload speed, dictated by the technology used.
corringham
Seasoned Champion
Fixes: 16
Both download and upload are affected by attenuation which increases with distance.
A "perfect" ADSL connection will have a download sync of 8Mbps, and upload of 880Kbps - so about a 10:1 ratio.
ADSL2+ will be 24Mbps down, 1.2Mbps up - so about a 20:1 ratio.
The upload frequencies are the lower frequencies so are attenuated a little less, so the ratios change with distance.
Leapy
Seasoned Champion
@corringham That sounds like a logical set of ratios😊 20:1 and 10:1.
In my area they advertise FTTP at 1GB down and 200mbs up or  5:1
I know that a lot of people never get their rated up speeds, so maybe that is a limit to the average "Golden Ratio"?
Champnet
Aspiring Hero
Fixes: 12
In my area they advertise FTTP at 900Mbps down and 900Mbps up or  1:1
Leapy
Seasoned Champion
@Champnet won't the same up and down impact on the effectiveness of the Asymmetric Digital Subscriber Line (ADSL)?🤔
With a perfect balance, up and down, at such a speed, how would you know if you're coming or going and it wouldn't  be Asymmetric any longer either? 🙄
FYI:- Asymmetric not identical on both sides of a central line; unsymmetrical; lacking symmetry😉
Champnet
Aspiring Hero
Fixes: 12
Apologies, it’s full fibre to the door. I was just comparing speed to your post above mine.
Advert here : Gigafast
